Gizmo Posted October 28, 2019 Share Posted October 28, 2019 Dear @Riela and guys, thanks for providing this info. We know about the problem and are trying to fix it. We need your help. Soon I will publish a solution that needs to be checked by those users who have this problem. Aliviax and Halderim 2 Link to comment Share on other sites More sharing options...
Halderim Posted October 28, 2019 Share Posted October 28, 2019 will do my best to help Gizmo Gizmo 1 Link to comment Share on other sites More sharing options...
CindySaphire Posted October 28, 2019 Share Posted October 28, 2019 Thank you for replying to the thread Gizmo, I am happy to test solutions. Updated the patch and i still have the glitch. oldType 1 Link to comment Share on other sites More sharing options...
DrCock Posted October 28, 2019 Share Posted October 28, 2019 (edited) It definitely sounds like something in the windows profile is corrupted then (that is why running the game with a different user account fixes the issue, as the game is now being run with the new profile). Hopefully an updated patch will fix whatever is broken in the profile for this game. Edited October 28, 2019 by soulburn74 CindySaphire 1 Link to comment Share on other sites More sharing options...
Gizmo Posted October 28, 2019 Share Posted October 28, 2019 (edited) Here is a test solution - Find new version here 1) Make a backup copy of the following files from the game directory: GameAssembly.dll 3DXChat_Data\il2cpp_data\Metadata\global-metadata.dat 2) Unzip the archive (test2.zip) into the game folder, replacing the files 3) Run the game and try to view profiles (only profiles need to be tested, gold and friendlists were not affected) 4) Be sure to restore the original files before updating to a new version, because the update will destroy the game Thank you very much for your help! Edited October 29, 2019 by Gizmo New version Aliviax, CindySaphire and Lisa 3 Link to comment Share on other sites More sharing options...
Halderim Posted October 28, 2019 Share Posted October 28, 2019 Ok with this I can view my own and other profiles again. That seems to work Gizmo and Aliviax 2 Link to comment Share on other sites More sharing options...
SkyDiver Posted October 28, 2019 Share Posted October 28, 2019 tested and no issues with friends list, all profiles opening up 100% at the time, and quick too, and xgold not affected too ^^ Gizmo and Aliviax 2 Link to comment Share on other sites More sharing options...
Aliviax Posted October 28, 2019 Share Posted October 28, 2019 22 minutes ago, Gizmo said: Here is a test solution Download test1.zip 1) Make a backup copy of the following files from the game directory: GameAssembly.dll 3DXChat_Data\il2cpp_data\Metadata\global-metadata.dat 2) Unzip the archive (test1.zip) into the game folder, replacing the files 3) Run the game and try to view profiles (only profiles need to be tested, gold and friendlists were not affected) 4) Be sure to restore the original files before updating to a new version, because the update will destroy the game Thank you very much for your help! I think its best also this fix be posted on the discord chanel also cause on discord way more ppl watch it Link to comment Share on other sites More sharing options...
Anaganda Posted October 28, 2019 Share Posted October 28, 2019 (edited) Doesn't work for me for some reason... FL still empty, gold zero and all that... and I did the steps... checked and double checked. edit: and also profile was empty Edited October 28, 2019 by Anaganda missed a part Link to comment Share on other sites More sharing options...
Halderim Posted October 28, 2019 Share Posted October 28, 2019 2 minutes ago, Anaganda said: Doesn't work for me for some reason... FL still empty, gold zero and all that... and I did the steps... checked and double checked. Only profiles are addressed in this test solution not the FL or gold Link to comment Share on other sites More sharing options...
Anaganda Posted October 28, 2019 Share Posted October 28, 2019 (edited) 6 minutes ago, Halderim said: Only profiles are addressed in this test solution not the FL or gold profile was empty also Edited October 28, 2019 by Anaganda Link to comment Share on other sites More sharing options...
oldType Posted October 29, 2019 Share Posted October 29, 2019 my profile began to be read, thanks. Gizmo 1 Link to comment Share on other sites More sharing options...
Light_Stripe Posted October 29, 2019 Share Posted October 29, 2019 (edited) I'v been having this issue since the 21st and the test file fixed viewing profiles for me, but friends list is still missing. Edited October 29, 2019 by Light_Stripe Gizmo 1 Link to comment Share on other sites More sharing options...
Gizmo Posted October 29, 2019 Share Posted October 29, 2019 (edited) Here is an updated solution (link removed) - Already implemented to build 401 Fixed: profiles, xgold, friend lists etc. 1) Make a backup copy of the following files from the game directory: GameAssembly.dll 3DXChat_Data\il2cpp_data\Metadata\global-metadata.dat 2) Unzip the archive (test2.zip) into the game folder, replacing the files 3) Run the game and try to view profiles, xgold and friend lists 4) Be sure to restore the original files before updating to a new version, because the update will destroy the game Thank you very much for your help! Edited October 31, 2019 by Gizmo Already implemented to build 401 oldType, Rodin, Light_Stripe and 3 others 5 1 Link to comment Share on other sites More sharing options...
SusanLouisa Posted October 29, 2019 Share Posted October 29, 2019 12 minutes ago, Gizmo said: Here is an updated solution Download test2.zip Fixed: profiles, xgold, friend lists etc. 1) Make a backup copy of the following files from the game directory: GameAssembly.dll 3DXChat_Data\il2cpp_data\Metadata\global-metadata.dat 2) Unzip the archive (test2.zip) into the game folder, replacing the files 3) Run the game and try to view profiles, xgold and friend lists 4) Be sure to restore the original files before updating to a new version, because the update will destroy the game Thank you very much for your help! I am sure many are grateful for this solution, but for some it is quite impossible. Game Directory? Back up? Restore? Unzip archive? Not all are programmers or have a clue of what you are talking about. Is it not possible for this issue to be repaired by game employed programmers in an update? Vaughan_Rarius 1 Link to comment Share on other sites More sharing options...
oldType Posted October 29, 2019 Share Posted October 29, 2019 thanks, it worked Gizmo 1 Link to comment Share on other sites More sharing options...
CindySaphire Posted October 29, 2019 Share Posted October 29, 2019 It worked for me! thank you Gizmo! Will we have to manually "fix" it every update? I assume those with the glitch will not be compensated for lost gold either from the loss of daily streaks/ability to get gold over the past few days. Gizmo 1 Link to comment Share on other sites More sharing options...
Lisa Posted October 29, 2019 Share Posted October 29, 2019 Hi all! This fix will be included in the next update. But first, volunteers are required for the test. If you are not interested, then just wait for the update. Thanks! Gizmo, CindySaphire and Aliviax 3 Link to comment Share on other sites More sharing options...
Anaganda Posted October 29, 2019 Share Posted October 29, 2019 Still doesn't work for me... but at least now I know my issue is my own, I can try and find a solution. Thanks for the effort, Gizzie & Lisa Gizmo 1 Link to comment Share on other sites More sharing options...
Halderim Posted October 29, 2019 Share Posted October 29, 2019 Even as others already tested it I can confirm too with the test2 files everything works as usual. @Anaganda Did you already try the workaround with a different windows user? Anaganda, Gizmo and CindySaphire 3 Link to comment Share on other sites More sharing options...
Anaganda Posted October 29, 2019 Share Posted October 29, 2019 1 minute ago, Halderim said: Even as others already tested it I can confirm too with the test2 files everything works as usual. @Anaganda Did you already try the workaround with a different windows user? mmmhm and didn't work also... furthering the idea that I have a totally different issue but for me using vpn even connecting to my own country with it, seems to solve the issue... but ofc it comes with lag... so I'll survive for now, till I find a solution. Thanks for the tips and your effort to help, dear Gizmo and CindySaphire 1 1 Link to comment Share on other sites More sharing options...
Anong Posted October 30, 2019 Share Posted October 30, 2019 The Performance of 3dx is very bad till the weekly update starts...big rooms often unplayable and some lil room too......somtimes many more ppl in the room but i cant see all of them....i hope u will fix it very fast Link to comment Share on other sites More sharing options...
AWahba Posted October 30, 2019 Share Posted October 30, 2019 (edited) Didn't work for me, i am having this issue now for a week its becoming very annoying i can't even log in the game now Edited October 30, 2019 by AWahba Link to comment Share on other sites More sharing options...
xxBELLAxx Posted October 30, 2019 Share Posted October 30, 2019 (edited) Hi there, since 4-5 days I can`t save my worlds nor load them. I tried everything. I waited ages for the loading, windows defender, anti virus, run the file browser as admin.. I tried serval times in row.. I even tried to load from a different harddisk. I tried the file from Gizmo right now and I could load a world, but not save it.. now its as before and I can`t load and save my rooms. It`s just me who has still this problem? Edited October 30, 2019 by xxBELLAxx typo Link to comment Share on other sites More sharing options...
Gizmo Posted October 31, 2019 Share Posted October 31, 2019 Update to 401 version, profiles frind list and xgold fixed Aliviax 1 Link to comment Share on other sites More sharing options...
