Lovers Posted July 9, 2017 Author Share Posted July 9, 2017 OK well done that man <3 .... yes running as admin worked you little hero you lol ....thanks xanar Gizmo, lisafelicia and oldwhitewolf 3 Link to comment Share on other sites More sharing options...
Ohsweetjazzy Posted July 9, 2017 Share Posted July 9, 2017 Yep. run the patcher.exe as admin, worked for me aswellWhere is patcher.exe? Is that the actual update? lisafelicia 1 Link to comment Share on other sites More sharing options...
Xanar Posted July 9, 2017 Share Posted July 9, 2017 JessicaX, Pierrousss, PurrTgirl and 1 other 4 Link to comment Share on other sites More sharing options...
Ohsweetjazzy Posted July 9, 2017 Share Posted July 9, 2017 Where is patcher.exe? Is that the actual update? I got it! Thanks. Link to comment Share on other sites More sharing options...
MiaTakeko Posted July 9, 2017 Share Posted July 9, 2017 same issue here ...sooo frustrating Link to comment Share on other sites More sharing options...
TylaStar Posted July 9, 2017 Share Posted July 9, 2017 I tried it, it didn't work. My game still gets stuck on the loading screen. Link to comment Share on other sites More sharing options...
Xanar Posted July 9, 2017 Share Posted July 9, 2017 Stuck on loading screen can be caused by either1) Corrupt avatar2) Clothing wich isn't availible in the new version. (For example, switching to 2.0 from 2.5 can cause that)3) Generally server isn't responding. Try the following, Tyla. Edit:Using the old DLL for the new client also causes a loading-bug Link to comment Share on other sites More sharing options...
TylaStar Posted July 9, 2017 Share Posted July 9, 2017 If its a corrupt avatar, how do I fix it? Link to comment Share on other sites More sharing options...
SamanthaSweetheart Posted July 9, 2017 Share Posted July 9, 2017 Yes, running the patcher as an administrator works. I'm using windows 10. Gizmo 1 Link to comment Share on other sites More sharing options...
Pierrousss Posted July 9, 2017 Share Posted July 9, 2017 same Link to comment Share on other sites More sharing options...
JessicaX Posted July 9, 2017 Share Posted July 9, 2017 #1 issue for blank load screen is people forgetting to put back original DLL before patching.However, even after doing that, I was stuck on "unzipping". I re-downloaded full game from members area and patched from there and it was fine. http://3dxchat.com/members/ Caren 1 Link to comment Share on other sites More sharing options...
Xanar Posted July 9, 2017 Share Posted July 9, 2017 @Pier: Try running Patcher.exe as admin and also disable Antivir for the update. @Tyla: Usually the support can help you with that. But I just replaced the old DLL and I got a loading bug. So if you are using the DLL, remove it and restore your original. Link to comment Share on other sites More sharing options...
TylaStar Posted July 9, 2017 Share Posted July 9, 2017 How do I do that?(I'm really bad with computers) Link to comment Share on other sites More sharing options...
Xanar Posted July 9, 2017 Share Posted July 9, 2017 If you know how to replace the DLL, then try this:This one is the original unmodified DLL from the new client in case you patched with the modded-dll. https://drive.google.com/open?id=0B-4iFATOQkQvUEt4aE5hOUVFNm8 Link to comment Share on other sites More sharing options...
Looana Posted July 9, 2017 Share Posted July 9, 2017 thats all i see Link to comment Share on other sites More sharing options...
Xanar Posted July 9, 2017 Share Posted July 9, 2017 Loo, try using the DLL from my link. You didn't remove Rochis DLL when updating.https://drive.google.com/open?id=0B-4iFATOQkQvUEt4aE5hOUVFNm8 Link to comment Share on other sites More sharing options...
gammareh Posted July 9, 2017 Share Posted July 9, 2017 I had the same problems. after Uninstall and Folder Delete I restarted the PC, installed and patched. now it works. Link to comment Share on other sites More sharing options...
TylaStar Posted July 9, 2017 Share Posted July 9, 2017 FINALLY! Thank you, Xanar. Link to comment Share on other sites More sharing options...
AHT Posted July 9, 2017 Share Posted July 9, 2017 well it worked perfectly for me. I don't use dll, and it's not set to run as admin, so yay 3dx! Link to comment Share on other sites More sharing options...
Looana Posted July 9, 2017 Share Posted July 9, 2017 i did remove it -.- i am not stupid Link to comment Share on other sites More sharing options...
Kinksters INC. Posted July 9, 2017 Share Posted July 9, 2017 How about this? With the recent update Defender detects some game files as trojan. Even tho when exclude Defender for some directories (such as 3DX folder, desktop etc), after the first launch Defender immediately deletes those files again and won't let the game run. I can run the game only if I completely disable Defender for any actions.. And of course I will not do that. Congratz @gizmo good job once again mate lol. Link to comment Share on other sites More sharing options...
Kinksters INC. Posted July 9, 2017 Share Posted July 9, 2017 https://www.youtube.com/watch?v=TAryFIuRxmQ oldwhitewolf 1 Link to comment Share on other sites More sharing options...
Felinia Posted July 9, 2017 Share Posted July 9, 2017 With the latest update, i do not see any avatars, i unistalled and reinstalled but nothing. After 5 times i see the avatars,ç_ç Link to comment Share on other sites More sharing options...
Dago Posted July 9, 2017 Share Posted July 9, 2017 In the Website I find only the 364... Link to comment Share on other sites More sharing options...
Dago Posted July 9, 2017 Share Posted July 9, 2017 Can someone please post a link to 365?Thanks in advance Link to comment Share on other sites More sharing options...
