Toran Posted December 21, 2021 Posted December 21, 2021 disconnect every some seconde or minutes , what happen ?
Music Posted December 22, 2021 Posted December 22, 2021 Is anybody going to do anything about this "Connection Lost" issue? It is getting annoying.....
DerekSoul Posted December 22, 2021 Posted December 22, 2021 everything is fine with the game, try EU / USA when logging into the game or another VPN service.
Music Posted December 22, 2021 Posted December 22, 2021 I am not using any vpn an no matter which server I use, I get those messages
Diana Prince Posted December 22, 2021 Posted December 22, 2021 try a free VPN and see if this makes a difference
MisterOiT Posted December 22, 2021 Posted December 22, 2021 Diana i don't know if vpn helps but it's been a few days in particular that 3dx is unstable. there are constant disconnections or the list of friends and rooms disappears. What is the problem? I don't know but it's very annoying.
Toran Posted December 22, 2021 Author Posted December 22, 2021 i have frind vith vpn and same truble has me so its not vpn who change thing
LadiesToyDE Posted December 22, 2021 Posted December 22, 2021 I'm not using VPN at all and its working without any issue for me. So maybe VPN is indeed the problem. Just try without using VPN...
Toran Posted January 23, 2022 Author Posted January 23, 2022 and again disconnect every some minutes or some seconds .....
Alkis Posted January 23, 2022 Posted January 23, 2022 I have the same problems since yesterday too. The selftest says everything is ok but I get a high ping like 168 ms.Using a VPN won't change anything except taking your bandwidth so if you have little it will be worse.Better servers would be appreciated
MistressBeryl Posted January 24, 2022 Posted January 24, 2022 For me it is five minutes up to maybe an hour. Music stream also randomly breaks but often without connection lost, so i have to disable - enable music in the sounds menu.
JenniferBoise Posted January 24, 2022 Posted January 24, 2022 Ich habe seit ca zwei wochen das Poblem,. dss ich jeden Tag um die gleiche Uhrzeit, 10:29 pm, lost connect habe. ich habe keine Zwangstrennung im router.
MistressBeryl Posted January 25, 2022 Posted January 25, 2022 4 hours ago, JenniferBoise said: Ich habe seit ca zwei wochen das Poblem,. dss ich jeden Tag um die gleiche Uhrzeit, 10:29 pm, lost connect habe. ich habe keine Zwangstrennung im router. Telekom Deuschland? Zwangstrennung durch Provider? Einfach danach mal sehen was der Router für eine Verbindungsdauer hat.
JenniferBoise Posted January 25, 2022 Posted January 25, 2022 1und1, eigentlich nie Probleme, Zwangstrennung ist deaktiviert.
