Ocean level reset
World editor bug ocean level
14 replies to this topic
#1 Xizl
Xizl
  • 261 posts
Posted 23 February 2019 - 05:23 AM
For some reason, ocean level in my room sometimes got reset to 0 level and I need to fix it in world editor again and again. Maybe someone else have this problem too or better say - any solution for this problem?
#2 MeiLing
MeiLing
    The fool who dreams
  • 8,177 posts
  • LocationMeiHenge
Posted 23 February 2019 - 05:41 AM
Sorry but there is no solution. I always had to reset the level too. it is not saved in the word file.
  • Xizl likes this
#3 Rockster
Rockster
  • 623 posts
Posted 23 February 2019 - 06:18 AM
I experienced this problem when I made a full-sized theatre. The front section slanted down so low it went through the sea and I had to keep lowering the sea-level. It would save sometimes but mostly it didn't and eventually it would always revert back to 0. I did not want my theatre underwater. In the end I had to lift the whole build up to get the sea out of the way. The best way to choose a new sea level and make it stay there no matter what, is to fly right back up into the air so ur whole build is in one block on the screen, click and drag across the entire build to select everything and it will all become highlighted. Choose the basic move icon and flycam to somewhere close to where your shoreline will be. Using only the up/down arrow widget, lift and lower the entire build so that the bottom edge is where u want it in relation to the sea level. When happy with your new sea level click 'save to file' and when pop-up window appears, locate your currently loaded build file. Click to highlight and then click OK, it will tell u this already exists, OK it and your build file now has it's new updated sea level.
  • Cordelia, MeiLing, Xizl and 1 other like this
#4 XXVladXX
XXVladXX
    Newbie
  • Pip
  • 3 posts
Posted 23 February 2019 - 09:50 AM
there is a solution, we need to lower the entire location, not raise the sea level. :P
#5 Xizl
Xizl
  • 261 posts
Posted 23 February 2019 - 10:42 AM
Thank you, Rockster!
#6 RobPathfinder
RobPathfinder
  • 881 posts
  • LocationNY
Posted 23 February 2019 - 11:12 PM
I had to help a friend lift his creation by dividing it into 4 different parts. Locking the direction to 5 (i needed to go 10 up) It became easy grabbing a section, saving the selected area and lifting that area in a new file. I did that four times then merged all four parts and saved the new file with the lifted room.
  • MeiLing likes this
#7 Briana
Briana
  • 4,176 posts
Posted 24 February 2019 - 04:01 AM
  • Phoenixsong likes this
#8 THX
THX
  • 472 posts
  • LocationIn Your Cortex.
Posted 24 February 2019 - 04:28 AM
I've found when you lower the sea it sometimes requires 2 saves.  Meaning you save... but you go in your room and find the sea back at zero even though you set it lower. One more save seems to do the trick.
*note  -7 meters makes names disapear.
  • Cassey and Xizl like this
#9 RobPathfinder
RobPathfinder
  • 881 posts
  • LocationNY
Posted 24 February 2019 - 04:16 PM
Raising or lowering the level will always require you to put in the number every time you open editor.
#10 THX
THX
  • 472 posts
Posted 04 May 2019 - 03:46 AM
Not always or even often.
I've been trying to isolate what triggers the ocean to return to default level but havn't been able to find a causality.
I do know this. Save, go into the property you saved and if the ocean is at deafault, go in set if back to what you want and remove it. It will save in world file at the height you chose after a second save 99% of the time.
#11 MeiLing
MeiLing
    The fool who dreams
  • 8,177 posts
  • LocationMeiHenge
Posted 04 May 2019 - 03:52 AM
each time you enter the editor, this value is reset.
#12 Phoenixsong
Phoenixsong
  • 140 posts
Posted 04 May 2019 - 12:49 PM
for me it would only be at the correct level if my last save was at that level and i had typed it in before the save, then it would stay there, but like others are saying, when you go back into editor it reverts to 0, even if it didn’t say that in the editor.
another buggy feature of 3dx
#13 RobPathfinder
RobPathfinder
  • 881 posts
  • LocationNY
Posted 04 May 2019 - 01:50 PM
That is awesome THX, I really hope you isolate it and you know maybe letting Gizmo that an ocean reset should be taken off would be a good idea. After all people that build rooms would love more freedom to create.
  • THX likes this
#14 THX
THX
  • 472 posts
Posted 08 May 2019 - 12:58 AM
I have been getting about the same amount of water resets with 64 as with 32. I am posting this so anyone else trying to diagnose this doesn't have to start from zero.
I am getting between between 3-7 saves per reset at -14 meters. One thing that sticks out to me is that if you go quickly into your room from WE that seems to trigger resets more often. I've been using the 30 second rule lately between saving, exiting WE, and going into a room. I pretty much always exceed 3-5 saves now before a reset.
#15 Briana
Briana
  • 4,176 posts
Posted 10 May 2019 - 03:00 AM
Also tagged with one or more of these keywords: World editor, bug, ocean level
