Blythe Posted November 23, 2020 Share Posted November 23, 2020 Anyone know a method to "scoop" an indentation into a primitive cube object? Trying to easily create a sink on the top of a kitchen cabinet. Of course, inserting a furniture library "bowl" only fills the bowl with the cube surface. Ideas please? Thanks All! __Blythe Link to comment Share on other sites More sharing options...
Anaganda Posted November 23, 2020 Share Posted November 23, 2020 you can't make holes in things... what you have to do is make your sink then build the counter around it, with multiple cube objects. Link to comment Share on other sites More sharing options...
Blythe Posted November 24, 2020 Author Share Posted November 24, 2020 Thanks Anaganda. That's what I expected - just hoping for something simpler. Appreciate the help Link to comment Share on other sites More sharing options...
TashaTight Posted November 24, 2020 Share Posted November 24, 2020 1 hour ago, Blythe said: Thanks Anaganda. That's what I expected - just hoping for something simpler. Appreciate the help Would suggest doing a cylinder in shape you want, put a different texture on it. Use that to build around with curved half holed square shape, copy it and used the rotate with center icon switched on, move it then add squares for the borders around those. At any case good luck with it, would been nice for sure if we had extrude and boolean functions to remove stuff. Diana Prince 1 Link to comment Share on other sites More sharing options...
Serenity Posted January 1, 2022 Share Posted January 1, 2022 This is what I do, the only drawback is it only makes round holes. There is an object in the editor that looks like a half square with a half circle in it. I simply copy and rotate around to make the hole, then build around it. If you want just a hole it can be resized both ways to make it oval , say, since it is an identical shape with the same geometry and there is only 2 objects. Just make sure your editor is set for center and not pivot. I have attached a picture with the object in question circled in red. Hope this helps. EagerHank 1 Link to comment Share on other sites More sharing options...
