grigoris Posted October 16, 2019 Share Posted October 16, 2019 Hi everyone, I have this issue, (trying to make group alligned to x y z axis) When we have a Group of items, we cannot edit Transform as it was a single item.(Group value is always 0). If you see the attached picture, I want to whole group to be straight on x y z axis (the Sofa + objects)....impossible as i can only do it piece by piece... Also Snap angle does not accept decimals Link to comment Share on other sites More sharing options...
JenC Posted October 16, 2019 Share Posted October 16, 2019 Im not quite sure if Im reading you right, but why dont you use the rotational tool? And make sure you have Center Axis selected before moving. Link to comment Share on other sites More sharing options...
grigoris Posted October 17, 2019 Author Share Posted October 17, 2019 I try to place and rotate the selected GROUP (Objects + SOFA ) at same position as the single placed SOFA (not selected)... Free rotating the group is too difficult and unacurate Link to comment Share on other sites More sharing options...
JenC Posted October 17, 2019 Share Posted October 17, 2019 (edited) I know its a bit difficult, but it can be done. The best way to do it is not free, but to drop the operational degrees from the standard 15 to 5, this gives you much better control. Also change the colour of that base to black or something dark to make it easier to see for aligning. then when you get as close as you can with 5, drop it back to 2 and you will be able to get it spot on. Edited October 17, 2019 by JenC ☙𝔼𝕩❧ 1 Link to comment Share on other sites More sharing options...
