vampireinblack Posted September 17, 2022 Posted September 17, 2022 If you hide the interface and then close the camera window, there is no way to get the interface or the camera window back. Maybe a shortcut to open the camera window would resolve this issue? Thank you!
Yvonny Posted September 17, 2022 Posted September 17, 2022 F1 key helps in that case to bring up the settings which then also brings up the UI again
MissD Posted September 18, 2022 Posted September 18, 2022 8 hours ago, vampireinblack said: If you hide the interface and then close the camera window, there is no way to get the interface or the camera window back. Maybe a shortcut to open the camera window would resolve this issue? Thank you! Normally SHIFT + Z should hide/unhide the UI, but it seems like you have found a bug, make sure to report it to @Gizmo
