Hi,
need help to play the game.
After log-in and starting the game, I can´t see any rooms and the worldchat did not work. 1 minute later i got the message "unable to connect"!
Using the mobile hotspot of my smartphone cause I am out for work and no wifi possible.
two days ago with wifi at home, everything works fine.
Any issues?
greetz
Fugazi
Sounds like you are getting high ping which would take time for everything to render up correctly. not sure what service you are using for hotspot but if 5g is giving you issues, try just using 4g or 4g lte.
  • 11 months later...
im having the same problem,my internet works everything works good i can log on but i cant see anyone then after a while i get disconected
