Querida69 Posted January 25, 2015 Share Posted January 25, 2015 Anyone that can post a guide on how to use the emote function for the new chat window? Link to comment Share on other sites More sharing options...
Cordelia Posted January 25, 2015 Share Posted January 25, 2015 I am not sure if there is anything more to it than using the /me command in front of any text. A small example, if I type Hi there! it appears as Cordelia: Hi there!However, if I type /me says "Hi there!" it will appear as Cordelia says "Hi there!" Another... /me is tired and is going to bed.appears as Cordelia is tired and is going to bed. They are just simple examples. It is not always appropriate and can be misused and abused (plus the color is atrocious) but it can also be used quite effectively. If there is anything else involved, I would be interested in knowing too. RedJewel, Babette and Tanyatranny 3 Link to comment Share on other sites More sharing options...
RedJewel Posted January 26, 2015 Share Posted January 26, 2015 I am not sure if there is anything more to it than using the /me command in front of any text. A small example, if I type Hi there! it appears as Cordelia: Hi there!However, if I type /me says "Hi there!" it will appear as Cordelia says "Hi there!" Another... /me is tired and is going to bed.appears as Cordelia is tired and is going to bed. They are just simple examples. It is not always appropriate and can be misused and abused (plus the color is atrocious) but it can also be used quite effectively. If there is anything else involved, I would be interested in knowing too. Thanks Cordella I was wondering how to do that . Link to comment Share on other sites More sharing options...
Kiest Posted January 26, 2015 Share Posted January 26, 2015 You can change the color of your text with the following line: "<color='color name'>'Your text'</color> You can combine this with the "/me" command to change the text color of whatever your emoting. I don't know if you can change the color of your name when you emote, though. Link to comment Share on other sites More sharing options...
Chilles Posted January 27, 2015 Share Posted January 27, 2015 The 3 red hearts <size=14><color=#bc0000>❤</Color></size><size=18><color=#6d0000>❤</Color></size><size=22><color=#ff0000>❤</Color></size> Link to comment Share on other sites More sharing options...
Rochi Posted January 27, 2015 Share Posted January 27, 2015 ^___^ Chilles 1 Link to comment Share on other sites More sharing options...
Querida69 Posted January 27, 2015 Author Share Posted January 27, 2015 Cordelia 1 Link to comment Share on other sites More sharing options...
Cordelia Posted January 27, 2015 Share Posted January 27, 2015 You learn quickly A couple of things... You can use <b> </b> (bold) and <i> </i> (italic) operators as well as the size and color that Achilles and Kiest mentioned. I've tried to change the color of the name in the /me but with no success. There don't appear to be any modifiable (easily modifiable, like textual) local settings files. Rochi's post looks great but I haven't found any way of producing multiple lines without pasting them individually. Is it possible to insert a CR/LF character somehow, in order to be able to copy a block? I don't condone flooding but it would be nice to be able to post multiple lines. Perhaps it is a problem with the new chat function as people used to be able to post multiple lines, I'm sure. Link to comment Share on other sites More sharing options...
Querida69 Posted January 27, 2015 Author Share Posted January 27, 2015 You learn quickly Actually, I wrote a small program to help me out for fancy formatting... Rochi's post looks great but I haven't found any way of producing multiple lines without pasting them individually. Is it possible to insert a CR/LF character somehow, in order to be able to copy a block? I don't condone flooding but it would be nice to be able to post multiple lines. Perhaps it is a problem with the new chat function as people used to be able to post multiple lines, I'm sure.It is possible to send a LF by code and get into place, however combining that with getting the unicode characters to wind up correctly was not as easy as I hoped.. Link to comment Share on other sites More sharing options...
brasco Posted March 31, 2015 Share Posted March 31, 2015 In profile text is aligned left, while in gifts is centrered. Is there any code which can manipulate this aligment? :rolleyes: Link to comment Share on other sites More sharing options...
