Cherry83 Posted November 17, 2021 Posted November 17, 2021 I haven't found a way to resolve this issue and its just waaay out of synch which ruins the entire purpose of it, for me at least. I have tried reconnecting it and rescanning the QR Code hundred of times, the firmware and drivers are up-to-date and my phone is on the same network as my PC. PC connected via LAN, my phone via WLAN (no VPN on either sides connected) Help?
Cherry83 Posted November 17, 2021 Author Posted November 17, 2021 Update: I just tried connecting my PC to WIFI instead of LAN which also didn't fix it.
hotmaya Posted November 17, 2021 Posted November 17, 2021 1 hour ago, Cherry83 said: Update: I just tried connecting my PC to WIFI instead of LAN which also didn't fix it. i guess it depends on how far you are away and how fast your internet speed is like. slow connection - slow synch.
Cherry83 Posted November 17, 2021 Author Posted November 17, 2021 42 minutes ago, hotmaya said: i guess it depends on how far you are away and how fast your internet speed is like. slow connection - slow synch. They are literally right next to each other and my internet speed is beyond sufficient.
hotmaya Posted November 17, 2021 Posted November 17, 2021 1 hour ago, Cherry83 said: They are literally right next to each other and my internet speed is beyond sufficient. hmmm. then i have no idea why its out of synch - do other have the same experience?
MissD Posted November 17, 2021 Posted November 17, 2021 No issue here, only thing I can think of is, double check your phone is connected to wifi and WiFi-Assist is turned off. Quote "Wi-Fi Assist lets your phone use your cellular data plan to boost your WiFi performance, in case of a weak or bad WiFi"
Cherry83 Posted November 21, 2021 Author Posted November 21, 2021 Update: I still couldn't fix it. Could I get some sort of technical support replying? I can't be the only one with this issue..
MissD Posted November 21, 2021 Posted November 21, 2021 Try contacting Eva support on discord, she might be able to help you out
Cherry83 Posted November 23, 2021 Author Posted November 23, 2021 Update: I managed to fix it myself by going into Ethernet Properties and enabling Internet Protocol Version 6 (TCP/IPv6) for anyone having the same issue.
