Abelar Posted July 27, 2014 Share Posted July 27, 2014 Hi, I did not use the game for some time so i had lots of updates to run. One of them froze the loading of the game so i uninstalled the game, downloaded it today et installed it again. But now, during the update 216 -> 217 i have this message (see attached pic).Any idea because i can't run the game anymore ? Thanks Link to comment Share on other sites More sharing options...
Rochi Posted July 27, 2014 Share Posted July 27, 2014 Did you remove the registries as you re installed it? Cant think of anything else currently, so after uninstall: Open Registry EditorGo to "HKEY_CURRENT_USER/Software/SexGameDevil/Right click the folder called 3DXChatSelect DeleteRe install the game using the fresh downloaded installerHope this helps! Gizmo, OliU and MiaTakeko 3 Link to comment Share on other sites More sharing options...
Abelar Posted July 28, 2014 Author Share Posted July 28, 2014 I uninstalled it again, cleaned the registries with Ccleaner, removed the folder in program files that was not erased by the uninstall and installed it again : it works ! Thanks for your advice. Gizmo 1 Link to comment Share on other sites More sharing options...
Gizmo Posted June 23, 2017 Share Posted June 23, 2017 I have created a little bat file that clears registry folder: "HKEY_CURRENT_USER/Software/SexGameDevil"1) Just download 3dx_reg_cleaner.bat file2) Click right mouse button on that file and select "Run as Administrator" OliU, ☙𝔼𝕩❧, llTonyll and 8 others 11 Link to comment Share on other sites More sharing options...
