pool
Drakkar
 Share
You have to use the ocean water for swimming, the prop water is just that, a prop.
Also, you need to have the pool edging lower than your floor of your house, if it is not, then water will lap through your house as you get the water to the height it needs to be in the pool, though if you dont care for the pool pose templates and how they work with the water, you could have the water level lower in the pool to stop this.
Edited by JenC
 Share
