Consuelo_ Posted June 23, 2020 Share Posted June 23, 2020 After the last update the game does not work properly. I get the fixed message "Connection lost" and despite everything allows me to chat with other users, but do not allow me to change rooms. I made several attempts by restarting my modem first, but unable to solve the problem I uninstalled and re-downloaded the game, but despite this the problem persists. Can anyone help me? Link to comment Share on other sites More sharing options...
tor Posted June 24, 2020 Share Posted June 24, 2020 You are not the only one:( The other avi's are also very dark and the females have no breasts.... HELP Link to comment Share on other sites More sharing options...
Tiffycatz Posted June 24, 2020 Share Posted June 24, 2020 (edited) Have the same issue after the recent update. Red box saying "connection lost". Can't go to character editor or select location places either. Rebooted several times, no help ! Update: Started working fine after I went through the edit tab of the logon screen. Exited and logged on as normal and all worked. Edited June 24, 2020 by Tiffycatz Update Link to comment Share on other sites More sharing options...
LaraF Posted June 24, 2020 Share Posted June 24, 2020 (edited) 4 hours ago, Tiffycatz said: Have the same issue after the recent update. Red box saying "connection lost". Can't go to character editor or select location places either. Rebooted several times, no help ! Update: Started working fine after I went through the edit tab of the logon screen. Exited and logged on as normal and all worked. The "Edit Tab" trick worked for me too! But it's still a little strange, isn't it? And "logon as normal" still doesn't work Edited June 24, 2020 by LaraF Link to comment Share on other sites More sharing options...
Mike Turtle Posted June 24, 2020 Share Posted June 24, 2020 Having issues with the patcher not working after Update 423. Contacted Customer Support and now await a reply. I even uninstalled the game and removed it from the Windows 10 64 Bit Home OS registry. Tried to reinstall it from 3DXChat's website but it is Update 317 that has a lot of corrupted files when you go to install it. Link to comment Share on other sites More sharing options...
AliceM Posted June 24, 2020 Share Posted June 24, 2020 It completely stopped letting the game( Server lost... What is going on with the servers? That throws, it is impossible to go ... And what does it mean "Edit Tab" and "logon as normal" ? Link to comment Share on other sites More sharing options...
Yvonny Posted June 24, 2020 Share Posted June 24, 2020 The Edit button start to play through that instead of going to a place, thats what they meant. AliceM 1 Link to comment Share on other sites More sharing options...
AliceM Posted June 24, 2020 Share Posted June 24, 2020 14 minutes ago, Yvonny said: The Edit button start to play through that instead of going to a place, thats what they meant. Thx) Link to comment Share on other sites More sharing options...
pretty Posted June 24, 2020 Share Posted June 24, 2020 (edited) 6 hours ago, Mike Turtle said: Having issues with the patcher not working after Update 423. Contacted Customer Support and now await a reply. I even uninstalled the game and removed it from the Windows 10 64 Bit Home OS registry. Tried to reinstall it from 3DXChat's website but it is Update 317 that has a lot of corrupted files when you go to install it. Update 423? Do you mean Build 423? The game only just now gave me Build 419, and everything is working fine for me. In the "What's New" portion of the login screen it says "Build 419", below that saying "Stability improvements and bug fixes". Edited June 24, 2020 by pretty Link to comment Share on other sites More sharing options...
AliceM Posted June 24, 2020 Share Posted June 24, 2020 He’s from the future) But still, after the update, he doesn’t let him into the game, although now he writes that there is no connection to the server ... Link to comment Share on other sites More sharing options...
AliceM Posted June 24, 2020 Share Posted June 24, 2020 LorenzoFr, xLilBabyGirlx and Tohi DM 3 Link to comment Share on other sites More sharing options...
pretty Posted June 24, 2020 Share Posted June 24, 2020 22 minutes ago, AliceM said: Server issues are not the same as bugs. The disconnects are due to server issues. Bugs are due to some error in the coding. As for fixing the server, they are currently in closed testing of the new server solution. Tohi DM 1 Link to comment Share on other sites More sharing options...
AliceM Posted June 24, 2020 Share Posted June 24, 2020 5 minutes ago, pretty said: Server issues are not the same as bugs. The disconnects are due to server issues. Bugs are due to some error in the coding. As for fixing the server, they are currently in closed testing of the new server solution. After the latest updates, server crashes began at one and the same time. After 418 and 419 updates, the problems became more ... Not only throws out the game, but also the problem with the entrance ... Link to comment Share on other sites More sharing options...
pretty Posted June 24, 2020 Share Posted June 24, 2020 The server crashes are related to peak server load times (player count spikes), which are not always the same times each day, and can happen more often on some days than on other days. Link to comment Share on other sites More sharing options...
AliceM Posted June 24, 2020 Share Posted June 24, 2020 Yes, I agree, but recently the server crashes suspiciously often ... Too suspiciously, moreover, after installing the updates ... Link to comment Share on other sites More sharing options...
pretty Posted June 24, 2020 Share Posted June 24, 2020 I understand it can seem to be related, but it really isn't. Link to comment Share on other sites More sharing options...
Loxy Posted June 25, 2020 Share Posted June 25, 2020 Hi , the game was working perfectly until the last patch , now it says cannot connect to te server but my friend and many others were ingame fine .. then it allowed me to connect and play as normal until I tried to reconnect a second time .. it seems it is allowing some players in and some others not so ... is it only allowing a certain number of members to play on the server at any one time? Thanks Nymphpott 1 Link to comment Share on other sites More sharing options...
Gman007 Posted June 25, 2020 Share Posted June 25, 2020 yup the stabilization patch pretty much just made things worse Link to comment Share on other sites More sharing options...
Valen Posted June 25, 2020 Share Posted June 25, 2020 Hmmm?? are the bug´s fixed so that they get even better? its a yoke? Version 418-stable no dc´s and version 419 unstable to much dc´s... find the problem.... Alliehotass 1 Link to comment Share on other sites More sharing options...
ColinDude Posted June 25, 2020 Share Posted June 25, 2020 Those stability improvements and bug fixes were probably client side. The same server side software is used and is unstable as hell. But currently it's REALLY bad I must say. Link to comment Share on other sites More sharing options...
Derai Posted June 25, 2020 Share Posted June 25, 2020 I would love to see some in depth ChangeLog or Patch Notes for once. Now it it feels like this... xLilBabyGirlx, LorenzoFr, Xizi and 3 others 2 4 Link to comment Share on other sites More sharing options...
Andaislu Posted June 25, 2020 Share Posted June 25, 2020 *Parks herself in the other virtual worlds until this one finally fixes it shit* xLilBabyGirlx 1 Link to comment Share on other sites More sharing options...
Xizi Posted June 25, 2020 Share Posted June 25, 2020 Gotta love those stability improvements... Link to comment Share on other sites More sharing options...
Valen Posted June 25, 2020 Share Posted June 25, 2020 (edited) Next disconnect.... next disconnect..... my pc runs more stable Edited June 25, 2020 by Valen Link to comment Share on other sites More sharing options...
IKushiel Posted June 25, 2020 Share Posted June 25, 2020 its more than once per hour := Link to comment Share on other sites More sharing options...
