Top Tips for an Easier Life.
top tips life hacks ideas tidier homes organised DIY Kitchen Garage useful advice
126 replies to this topic
#21 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 10 March 2019 - 03:51 PM
Computer Keyboard Short Cut Keys
Description
Alt+F  - File menu options in current program.
Alt+E  - Edit options in current program.
Alt+Tab - Switch between open programs.
F1 - View help information (F1 is used by almost every Windows program to display help).
F2 - Rename a selected file.
F5 - Refresh the current program window.
Ctrl+N - Create a new or blank document in some software, or open a new tab in most Internet browsers.
Ctrl+O - Open a file in the current software.
Ctrl+A - Select all text.
Ctrl+B - Change selected text to be bold.
Ctrl+I - Change selected text to be in italics.
Ctrl+U - Change selected text to be underlined.
Ctrl+F - Open find window for current document or window.
Ctrl+S - Save current document file.
Ctrl+X - Cut selected item.
Shift+Del - Cut selected item.
Ctrl+C - Copy selected item.
Ctrl+Ins -Copy selected item
Ctrl+V - Paste
Shift+Ins - Paste
Ctrl+Y - Redo last action.
Ctrl+Z - Undo last action.
Ctrl+K - Insert hyperlink for selected text.
Ctrl+P - Print the current page or document.
Home - Goes to beginning of current line.
Ctrl+Home - Goes to beginning of document.
End - Goes to end of current line.
Ctrl+End -Goes to end of document.
Shift+Home - Highlights from current position to beginning of line.
Shift+End - Highlights from current position to end of line.
Ctrl+Left arrow - Moves one word to the left at a time.
Ctrl+Right arrow - Moves one word to the right at a time.
Ctrl+Esc - Opens the Start menu.
Ctrl+Shift+Esc - Opens Windows Task Manager.
Alt+F4 - Close the currently active program.
Alt+Enter - Open the properties for the selected item (file, folder, shortcut, etc.).
  • SusanLouisa, AndrewweS, Stevezker and 5 others like this
#22 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 10 March 2019 - 03:57 PM
How to Make Symbols:
USE the numerical keys on the right of your keyboard, not the numbers across the top
How+to+make+symbols+with+keyboard+shortc
Shortcut Keys
Special Character
Alt+0224  - à
Alt+0232  -  è
Alt+0236  -  ì
Alt+0242  -  ò
Alt+0241  -  ñ
Alt+0228  -  ä
Alt+0246  -  ö
Alt+0252  -  ü
Alt+0248  -  ø
Alt+0223  -  ß
Alt+0198  -  Æ
Alt+0231  -  ç
Alt+0191  -  ¿
Alt+0176  -  °  (degree symbol)
Alt+0177  -  ±  (plus/minus symbol)
Alt+0153  -
Alt+0169  -  ©
Alt+0174  -  ®
Alt+0128  -  €  (Euro currency)
Alt+0162  -  ¢  (Cent symbol)
Alt+0163  -  £  (British Pound currency)
Alt+0165  -  ¥  (Japanese Yen currency)
  • SusanLouisa likes this
#23 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 10 March 2019 - 04:11 PM
Below are the top 10 keyboard shortcuts recommend everyone to memorize and use.
1.   Ctrl+C or Ctrl+Insert and Ctrl+X
Both Ctrl+C and Ctrl+Insert will copy highlighted text or a selected item. If you want to cut an item instead of copying it, press Ctrl+X. This action removes the text or item and stores it in the clipboard for you, rather than just copying it to the clipboard while leaving the original behind.
Apple computer users can substitute the Ctrl key for the command (cmd) key on their computers. For example, pressing Cmd+C copies highlighted text.
2.  Ctrl+V or Shift+Insert
Both the Ctrl+V and Shift+Insert will paste the text or object that's stored in the clipboard.
On Apple computers, use Cmd+V instead.
3.  Ctrl+Z and Ctrl+Y
Pressing Ctrl+Z will undo any change. For example, if you cut text, pressing this key combination will undo the cut. These shortcuts can also be pressed multiple times to undo or redo multiple changes. Pressing Ctrl+Y would redo the undo.
On Apple computers, use Cmd+Z and Cmd+Y to undo and redo.
4.  Ctrl+F and Ctrl+G
Pressing Ctrl+F opens the Find field, which allows you to search the text currently displayed in any program that supports it. For example, Ctrl+F can be used in your Internet browser to find text on the current page. Press Ctrl+F now to open the Find in your browser and search for "shortcut" to display each time shortcut is mentioned on this page.
On Apple computers, use Cmd+F to find.
Ctrl+G may be used to repeat a search (from using Ctrl+F) in a document or on a web page.
5.   Alt+Tab or Ctrl+Tab
Pressing Alt+Tab switches between open programs moving forward. For example, if you have your browser window open and other programs running in the background press and hold Alt and then press the Tab key to cycle through each open program.
On Apple computers instead of using the Alt key use the Command (Cmd) key. For example, Cmd+Tab to switch between open programs.
Bonus Tip: Press Ctrl+Tab to switch between tabs in a program. For example, if you have multiple tabs open in your Internet browser, press Ctrl+Tab to switch between them.
Bonus Tip: Adding the Shift key to Alt+Tab or Ctrl+Tab moves backward. For example, if you are pressing Alt+Tab and pass the program you want to use, press Alt+Shift+Tab to move back to that program.
Bonus Tip: Windows Vista, 7, 8, and 10 users can also press the Windows Key+Tab to switch through open programs in a full screenshot of the window.
6.  Ctrl+Backspace and Ctrl+Left or Right arrow
Note: The following shortcuts are for PC users only and do not work on Apple computers.
Pressing Ctrl+Backspace will delete a full word at a time instead of a single character.
Holding down the Ctrl key while pressing the left or right arrow will move the cursor one word at a time instead of one character at a time. If you want to highlight one word at a time, hold down Ctrl+Shift, then press the left or right arrow key. Your highlighted selection will move one word at a time in that direction.
7.   Ctrl+S
While working on a document or another file in almost every program, pressing Ctrl+Ssaves that file. Use this shortcut key frequently if you're working on anything important in case an error happens, you lose power, or any other issues that could cause you to any work since the last save.
On Apple computers, use Cmd+S to save a file.
8.   Ctrl+Home or Ctrl+End
Ctrl+Home will move the cursor to the beginning of the document, and Ctrl+End will move the cursor to the end of a document. These shortcuts work with most documents, as well as web pages.
On Apple computers use Command and the Cmd and the up arrow to get to the beginning of a document or text or Cmd and the down arrow to get to the end of a document or text.
9.   Ctrl+P
Control+P is used to open a print preview of the page or document currently being viewed. For example, press Ctrl+P now to view a print preview of this page.
On Apple computers use Cmd+P to open the print preview.
10.   Page Up, Spacebar, and Page Down
As you may have guessed, pressing either the page up or page down key will move to the next or previous page. When browsing the Internet, pressing the spacebar moves the scrollbar down a page. Similarly, Shift+spacebar moves the scrollbar up one page.
#24 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
  • LocationBlowing Bubbles
Posted 12 March 2019 - 09:36 AM
  • Vaughan_Rarius likes this
#25 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 12 March 2019 - 09:49 AM
30 HOUSEHOLD HACKS THAT WILL MAKE YOUR LIFE A WHOLE LOT EASIER
#26 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 15 March 2019 - 12:58 PM
#27 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
Posted 16 March 2019 - 05:24 AM
#28 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 18 March 2019 - 03:55 PM
Use a Soda Tab to Double Hanging Space
Pop off the tab of your favorite soft drink and use it to double up your hangers. Group like shirts together to easily find what you need.
closet-hacks-use-a-soda-tab-to-double-th
#29 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 18 March 2019 - 04:05 PM
Shower Rings
Instead of devoting a hanger to each of your scarfs (or worse, knotting multiples on one and causing major wrinkles) or belts or baseball hats, use shower rings to create individual holders for your entire collection.
1456429153-closet-shower-rings.jpg?crop=
#30 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 18 March 2019 - 04:06 PM
Stop Letting Shirts Slip
Nothing causes more mayhem in your closet than shirts that refuse to stay on their hangers. But pipe cleanerscan help prevent that annoying mishap and the resulting wrinkles.
1456428930-closet-no-slip-hanger.jpg?cro
#31 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 25 March 2019 - 06:36 PM
#32 Vaughan_Rarius
Vaughan_Rarius
    Master V
  • 5,063 posts
Posted 25 March 2019 - 06:55 PM
Use This Simple ‘Drop Test’ to See if Your Batteries Are Juiced.
Drop each battery (with the flat, negative end down) from a couple of inches up. If the battery is charged, it should make a solid thud and most likely stay standing. If, however, the battery is dead, it will bounce and fall over immediately.
http://petapixel.com...ies-are-juiced/
#33 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
Posted 25 March 2019 - 08:20 PM
#34 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
Posted 25 March 2019 - 08:23 PM
  • Vaughan_Rarius and Kaitlyn1989 like this
#35 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
Posted 26 March 2019 - 06:42 PM
#36 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
Posted 26 March 2019 - 06:43 PM
#37 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
Posted 26 March 2019 - 06:45 PM
#38 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
Posted 26 March 2019 - 06:47 PM
#39 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
Posted 26 March 2019 - 06:48 PM
#40 SusanLouisa
SusanLouisa
    MrsBrandiWineRarius
  • 3,125 posts
Also tagged with one or more of these keywords: top tips, life, hacks, ideas, tidier homes, organised, DIY, Kitchen, Garage, useful advice
