shorty Posted January 19, 2018 Share Posted January 19, 2018 I was wonder if there is an easy way of aligning my created parts? Really a pain to get proper alignment of parts so there is no LINE showing. Any help is appreciated. Really time consuming to do it. I could be dancing or laying on the beach smiles Sometimes gets very disgusted and do thinks like below photo ROFL Shorty Link to comment Share on other sites More sharing options...
Heden Posted January 19, 2018 Share Posted January 19, 2018 You can't align elements but you should always build walls based on gridTip: Set your grid to 0.125, 0.25, 0.5 or 1 so then everything will align nicely. However WorldEditor has a bug which moves and rotate a tiny bit some small element depending on their position and angle... Probably an error with decimal values... Link to comment Share on other sites More sharing options...
Zokora Posted January 20, 2018 Share Posted January 20, 2018 I import the world files into excel and align the objects there, as I can use formulas and a table view to do so. Link to comment Share on other sites More sharing options...
Losst AKA AnnieBunny Posted January 20, 2018 Share Posted January 20, 2018 Use B and V hotkeys. And read manual next time. Link to comment Share on other sites More sharing options...
Alliehotass Posted January 20, 2018 Share Posted January 20, 2018 Ok this tha way to get no lines. Listen up soldier, stand to attention and pay attention, ill say dis once and then youll go practice until ya hands bleed. When building a wall that joins to another wall for instance, a 90 degree corner, ie an L shape as in pics. Make your snap to grid values, 0.125 for smaller moves or 0.25 for larger moves. Best to keep this value tha same thru entire build so tings line up with older tings you have made. Ah use 0.125. Enable both snapping tools. 1. Make tha first wall, Plonk!2. Copy that wall, Zwoop!3. Select tool shown in pic.Click!4. Click and hold tha green dot. Doink! 5. Drag to the right. Swoosh! 6. Click tha red dot and do tha same. Doink! You have a join with No Lines. Shazzams! You can build this way for mostly everyting and you can also put one object ( if they use tha same texture) into another slightly and have no line if this way isn't appropriate. Read tha Help tool everyting is there. Now hut 2 3 4 move ya bunnz Recruit!! JessicaX, Ceres and AshleAnaDawn 3 Link to comment Share on other sites More sharing options...
Heden Posted January 20, 2018 Share Posted January 20, 2018 Still that would be helpful to have classic align tools (left, center, right, top, middle, bottom, front, between, back) Link to comment Share on other sites More sharing options...
chloe Posted January 21, 2018 Share Posted January 21, 2018 Still that would be helpful to have classic align tools (left, center, right, top, middle, bottom, front, between, back) Alliehotass 1 Link to comment Share on other sites More sharing options...
Becky_Anderson Posted February 3, 2018 Share Posted February 3, 2018 Use B and V hotkeys. And read manual next time. Wow. That is awfully rude. observer101, Heden and Ceres 3 Link to comment Share on other sites More sharing options...
