MiloTime80 Posted June 12, 2014 Share Posted June 12, 2014 Hello all So I am having an issue advancing through the Home Editor tutorial.... When I start clicking through the tutorial I get stuck on the step that asks you to right click on the mouse to rotate it. I do this and rotate the selected piece of furniture but it never checks that item off so I can move through to the next step and be done with it. Anybody have a similar issue with this? I contacted support and they said they would look into it, but I haven't heard anything back. All suggestions welcome and thanks! ArachneMW 1 Link to comment Share on other sites More sharing options...
ArachneMW Posted June 12, 2014 Share Posted June 12, 2014 Hi Milo! I have the exact same problem, every time. It feels quite annoying. I just learned to ignore it. The good thing is, you can still edit your home even if you do not complete the tutorial. Good luck, and let us know if Support has any help to give! Link to comment Share on other sites More sharing options...
Guest Suikazura Posted June 12, 2014 Share Posted June 12, 2014 I don't recall doing the tutorial, though probably did. But from other games, it is often you need to do it a certain way. So did you try doing a complete rotation of the item and/or try both directions? I have run into this in other games and it ended up being they wanted you to rotate it clockwise, 1 full turn, not counterclockwise (for example). Skylar 1 Link to comment Share on other sites More sharing options...
Rochi Posted June 12, 2014 Share Posted June 12, 2014 If this annoys you somehow, heres a way to check the tutorials "Done" Open Registry EditorGo to "HKEY_CURRENT_USER/Software/SexGameDevil/3DXChatFind the name of the tutorial you want completedRight click it, select Modify set value to 1If you want to do any tutorials again, set them to 0 chloe, Skylar, Gizmo and 4 others 7 Link to comment Share on other sites More sharing options...
ArachneMW Posted June 13, 2014 Share Posted June 13, 2014 OMG, Rochi knows so much!!! *feels impressed* I'll try it as well! Link to comment Share on other sites More sharing options...
MiloTime80 Posted June 13, 2014 Author Share Posted June 13, 2014 Thanks you for the replies... the problem I have is that it wont let me fully mod my home without going through the complete tutorial... so I cant edit and delete my furniture Link to comment Share on other sites More sharing options...
MiloTime80 Posted June 13, 2014 Author Share Posted June 13, 2014 Thanks Rochi!!! Link to comment Share on other sites More sharing options...
MiloTime80 Posted June 13, 2014 Author Share Posted June 13, 2014 One more question... how do you delete a piece of furniture? I tried to doubleclick and it doesn't work... Link to comment Share on other sites More sharing options...
Rochi Posted June 13, 2014 Share Posted June 13, 2014 Choose it and click delete key on keyboard. I noticed after doing so you wont be able to move unless you delete something the double click way, but thats the only other way i know Link to comment Share on other sites More sharing options...
MiloTime80 Posted June 14, 2014 Author Share Posted June 14, 2014 works! thanks again Rochi!! Link to comment Share on other sites More sharing options...
oQTRo Posted July 12, 2014 Share Posted July 12, 2014 I was directed to this thread and found all ROCHI advance thorough and accurate. THANK YOU so much for giving great advise to newbies and shows us how to utilize this site correctly. Link to comment Share on other sites More sharing options...
.Luli. Posted July 12, 2014 Share Posted July 12, 2014 Thank you, has been very helpful . I thought would have to die with this issue. Link to comment Share on other sites More sharing options...
modyalix Posted December 26, 2014 Share Posted December 26, 2014 hello GuysI have got a problem in the game downloads please helperror during updateDownload failed for : patcher /files/standalone windows-249-250.m2h PatcherWhat can i do To fix this problem and thank you .... Link to comment Share on other sites More sharing options...
Leeloo Posted December 26, 2014 Share Posted December 26, 2014 Hello all So I am having an issue advancing through the Home Editor tutorial.... When I start clicking through the tutorial I get stuck on the step that asks you to right click on the mouse to rotate it. I do this and rotate the selected piece of furniture but it never checks that item off so I can move through to the next step and be done with it. Anybody have a similar issue with this? I contacted support and they said they would look into it, but I haven't heard anything back. All suggestions welcome and thanks! to not be stuck , you must rotate the furniture doing a 360° rotation Link to comment Share on other sites More sharing options...
Guest Loonie Posted December 26, 2014 Share Posted December 26, 2014 to not be stuck , you must rotate the furniture doing a 360° rotation it was a long time ago ) Link to comment Share on other sites More sharing options...
