gammareh Posted December 3, 2016 Share Posted December 3, 2016 as this is not a technical issue with 3dx itself I place my post here: Seems I can't use Gyazo ingame. I always have to do a screenshot and then use Gyazo outside 3dx to post a link to a picture. Does anybody know if there's a solution to this problem? I run Gyazo in administrator mode Any help appreciated. Gamma Link to comment Share on other sites More sharing options...
Nikki Posted December 3, 2016 Share Posted December 3, 2016 Sometimes it happens with Lightshot too after patch. Then after some time it works again. Weird. gammareh 1 Link to comment Share on other sites More sharing options...
Nikki Posted December 4, 2016 Share Posted December 4, 2016 No doubt it is. But it does not always work with 3DXChat sometimes (for some weird reason) gammareh 1 Link to comment Share on other sites More sharing options...
Xanar Posted December 4, 2016 Share Posted December 4, 2016 It happends, if you run 3DX as admin. Just close it after patching and reopen it, then Gyazo should work again. gammareh 1 Link to comment Share on other sites More sharing options...
gammareh Posted December 4, 2016 Author Share Posted December 4, 2016 Thanks for your replies :-) I skipped Gyazo now and will give Lightshot a try. I already like the functionality. Gamma RobT 1 Link to comment Share on other sites More sharing options...
Xanar Posted December 4, 2016 Share Posted December 4, 2016 I prefer Gyazo because of the GIF-Capture gammareh 1 Link to comment Share on other sites More sharing options...
gammareh Posted December 4, 2016 Author Share Posted December 4, 2016 I prefer Gyazo because of the GIF-Capture Xan, i probably would, too, if it worked. You might imagine that if Gyazo doesn't work ingame, then Gyazo-gif doesn't either. Link to comment Share on other sites More sharing options...
Xanar Posted December 4, 2016 Share Posted December 4, 2016 As I said Gamma, I never had any problems with Gyazo, only after I ran 3DX as admin but usually a restart as normal user after patchday fixed it for me. LauraTWK 1 Link to comment Share on other sites More sharing options...
gammareh Posted December 4, 2016 Author Share Posted December 4, 2016 I can't switch back, Rob. I have to run 3dx in admin mode, because I also need the functionality of the ingame camera. If Gyazo does not work ingame in admin-mode, then I have to say goodbye anyway. No offence meant, Xani :-) RobT 1 Link to comment Share on other sites More sharing options...
gammareh Posted December 5, 2016 Author Share Posted December 5, 2016 Lightshot is nice, but relatively slow compared to Gyazo. Might relate to the fact that the options there don't offer a file size limit. I think my solution will be to work with both. They don't block each other and so I can always decide which software is best for the current purpose. As my main tool is still the ingame camera, I'll keep you informed about how my extensive 3dx shooting is proceeding :-) Link to comment Share on other sites More sharing options...
Xanar Posted December 5, 2016 Share Posted December 5, 2016 I can't switch back, Rob. I have to run 3dx in admin mode, because I also need the functionality of the ingame camera. If Gyazo does not work ingame in admin-mode, then I have to say goodbye anyway. No offence meant, Xani :-) Run Gyazo as admin as well Link to comment Share on other sites More sharing options...
gammareh Posted December 5, 2016 Author Share Posted December 5, 2016 I already do Xani. Unfortunately to no effect. Link to comment Share on other sites More sharing options...
gammareh Posted December 16, 2016 Author Share Posted December 16, 2016 update. It seems admin mode is no longer necessary to use the ingame camera. So I can use cam, lightshot and gyazo depending on what is best for the purpose. the only thing not yet working is gif. Link to comment Share on other sites More sharing options...
gammareh Posted December 16, 2016 Author Share Posted December 16, 2016 I can start it, but when I click to draw the frame I jump out of 3dx. Link to comment Share on other sites More sharing options...
gammareh Posted December 16, 2016 Author Share Posted December 16, 2016 Windowed Mode! So this was what caused the trouble. I had to switch to it. Link to comment Share on other sites More sharing options...
Kuru Posted December 16, 2016 Share Posted December 16, 2016 I use Gyazo and have had no problems with it. Usually what I do is turn the overall screen to WINDOWED from settings. Or simply press alt+Enter. Once I change it to a windowed look I simply go up top and drag it up or down just a bit so that my Gyazo icon can show at the bottom of my task bar. And I just take pictures that way.❄ Link to comment Share on other sites More sharing options...
gammareh Posted December 16, 2016 Author Share Posted December 16, 2016 Kuru, that's what is the most funny thing. I don't like windowed mode. and Gyazo pics work fine in full mode. but not gif. Link to comment Share on other sites More sharing options...
