Scarvers Posted May 14, 2014 Share Posted May 14, 2014 What are they I didnt see anything stating this... thinking of joining and curious to see if I will be able to run. Link to comment Share on other sites More sharing options...
Guest Suikazura Posted May 14, 2014 Share Posted May 14, 2014 It will run well on my 2 year old samsung laptop on medium. My 5 year old desktop with Nvidia gtx285 cards will run it at extreme with no lag. Do you know what your system specs. are? Maybe someone has a similar system and can give you a better response. Link to comment Share on other sites More sharing options...
Alrood Posted May 14, 2014 Share Posted May 14, 2014 Well...here's a quick run down on the minimum and recommended specs in order for you to run the game. This is according to my observations on running the game in different specifications. Currently, I run the game on my 8 month old MSI Gaming Laptop on Extremely High settings at 1600x900 Windowed mode resolution. Here's the specs for my machine:Intel Core i7-3630M 2.40Ghz with Integrated Intel HD Graphics 4000NVIDIA GeForce GTX 670MX @ 3GB GDDR5 VRAM16GB DDR3 RAM750GB HDDand a 100Mbps Internet Connection Minimum Requirements (for basically just being able to run the game lag-free with graphics on low and a fair resolution [was able to tell so by testing in my laptop with just the Integrated Graphics] ):Any Dual-Core processor with Integrated Graphics or 3.0 GHz Pentium 4 equivalentOnboard(Integrated) Graphics Card must at least have 512MB VRAMAt least 2 GB of RAM2GB of free HDD Spaceand at least 256Kbps Internet Connection Recommended Requirements (for running the game in Extremely high graphics and HD resolution with low zone load times):Any current Dual or Quad-Core processor (preferably 3rd Gen Core i5 or i7)DIscrete Graphics Card with DDR3 1GB VRAM (should support DirectX10 or 11, and should also support latest Pixel Shader versions and all related stuff)4GB of RAM would be Ideal2GB of free HDD Spaceand 2-4Mbps Internet Connection Hope this helps! =) Chilles and LEKS 2 Link to comment Share on other sites More sharing options...
Guest Suikazura Posted May 14, 2014 Share Posted May 14, 2014 I am running on a 312kbps DSL connection with no connection issues, though zone load times can be a little high. You don't need an extremely fast internet connection. Link to comment Share on other sites More sharing options...
Alrood Posted May 14, 2014 Share Posted May 14, 2014 I am running on a 312kbps DSL connection with no connection issues, though zone load times can be a little high. You don't need an extremely fast internet connection. Hehe...well the reason why i recommended a sort of high internet connection speed is so that the zone load times would be lessened for I think it's ideal for an optimal experience Then again I suppose it also works from I guess 256Kbps DSL Connections upwards * Edited the above post to reflect the change in the internet speed requirement. Thanks Suikazura Link to comment Share on other sites More sharing options...
Guest Suikazura Posted May 14, 2014 Share Posted May 14, 2014 Hehe...well the reason why i recommended a sort of high internet connection speed is so that the zone load times would be lessened for I think it's ideal for an optimal experience Then again I suppose it also works from I guess 256Kbps DSL Connections upwards Not everyone has access to high speed internet, so setting a much higher than needed access speed may cause people to not join this game. When, in actuality, their system is quite adequate to run the game with no issues. This community is small enough already, without scaring new people away Alrood 1 Link to comment Share on other sites More sharing options...
Alrood Posted May 14, 2014 Share Posted May 14, 2014 Not everyone has access to high speed internet, so setting a much higher than needed access speed may cause people to not join this game. When, in actuality, their system is quite adequate to run the game with no issues. This community is small enough already, without scaring new people away Gotcha... Thanks for that Link to comment Share on other sites More sharing options...
Alrood Posted May 14, 2014 Share Posted May 14, 2014 I suppose gizmo could help us out with this... I think if I'm not mistaken, the minimum requirements are listed on the SGD Site, but not on the 3DX site, so it might be beneficial if the 3DX Site is updated to show the minimum requirements as well Link to comment Share on other sites More sharing options...
Guest Suikazura Posted May 14, 2014 Share Posted May 14, 2014 I forgot about the sexgamedevil site. This is from that site. I didn't see a connection speed listed. System requirementsProcessor: 2.0 GHz + (3 GHz Pentium 4 or equivalent rec.) Graphics Card: GeForce™ 6600, Radeon™ 9600 or higher Memory: 512 MB OS: Windows XP / Vista / 7 / 8 Netbooks and old laptops are not supported! Link to comment Share on other sites More sharing options...
Alrood Posted May 14, 2014 Share Posted May 14, 2014 I might have to argue with the 512MB minimum requirement...because as of the moment in order for the game to run flawlessly in any graphics setting, you must have at least 2GB of RAM since the game could eat up a fluctuating rate of 520MB-800MB if one's going to check in Task Manager Of course you also have to consider the other background tasks running in the computer at the moment while you're running the game I'm guessing anything lower than 2GB, you'll have the "Low Memory" error popping up in Windows even with Page File turned on Or perhaps that's just me and my opinion... Chilles 1 Link to comment Share on other sites More sharing options...
Chilles Posted May 14, 2014 Share Posted May 14, 2014 My Minimum specifications with my old Travel Laptop:I think this thing is 10 Years old HP Pavilon TX2590eo AMD Turion X2 Ultra Dual-Core Mobile ZM-80 2.10GHzRam: 2,75GBGraphics: ATI Radeon HD3200Free Hardrive Space: 1GB Internet: Mobility Internet: often EDGE with 64kbit/s The Game runs with 1280x720 in Window Mode and Low Graphics But the Game runs full in the Ram with 974MB, Ram Is important for the Game for a stability System I recommend 4GB Ram Alrood and Gizmo 2 Link to comment Share on other sites More sharing options...
LEKS Posted May 14, 2014 Share Posted May 14, 2014 Well...here's a quick run down on the minimum and recommended specs in order for you to run the game. This is according to my observations on running the game in different specifications. Currently, I run the game on my 8 month old MSI Gaming Laptop on Extremely High settings at 1600x900 Windowed mode resolution. Here's the specs for my machine:Intel Core i7-3630M 2.40Ghz with Integrated Intel HD Graphics 4000NVIDIA GeForce GTX 670MX @ 3GB GDDR5 VRAM16GB DDR3 RAM750GB HDDand a 100Mbps Internet Connection Minimum Requirements (for basically just being able to run the game lag-free with graphics on low and a fair resolution [was able to tell so by testing in my laptop with just the Integrated Graphics] ):Any Dual-Core processor with Integrated Graphics or 3.0 GHz Pentium 4 equivalentOnboard(Integrated) Graphics Card must at least have 512MB VRAMAt least 2 GB of RAM2GB of free HDD Spaceand at least 256Kbps Internet Connection Recommended Requirements (for running the game in Extremely high graphics and HD resolution with low zone load times):Any current Dual or Quad-Core processor (preferably 3rd Gen Core i5 or i7)DIscrete Graphics Card with DDR3 1GB VRAM (should support DirectX10 or 11, and should also support latest Pixel Shader versions and all related stuff)4GB of RAM would be Ideal2GB of free HDD Spaceand 2-4Mbps Internet Connection Hope this helps! =)Woa man yours system is very cool! Link to comment Share on other sites More sharing options...
Alrood Posted May 14, 2014 Share Posted May 14, 2014 Woa man yours system is very cool! Hehe, thanks man Well it's worth every penny when I bought it Gotta enjoy playing games on this rig Link to comment Share on other sites More sharing options...
Leeloo Posted May 14, 2014 Share Posted May 14, 2014 Mine is less than that but i can play in low resolution without lag and medium with lag when there is more than 10 avatars lol I'm actually saving money to buy an alienware but it will be at the end of the year , around hmmmm ..... christmas Chilles 1 Link to comment Share on other sites More sharing options...
Chilles Posted May 14, 2014 Share Posted May 14, 2014 Mine is less than that but i can play in low resolution without lag and medium with lag when there is more than 10 avatars lol I'm actually saving money to buy an alienware but it will be at the end of the year , around hmmmm ..... christmas I see much black breast nipples, I'm not sure, is this from to much smoking or is the reason my bad Travel Laptop But my next Travel Laptop is very soon a Surface Pro 2 in the 8GB DDR3 Version! I don't like a gamer Laptop, for this I use my Desktop PC or the XBox. 3DXchat is the one and only PC game now I like a good work machine. On my Home Laptop I can play the Game in Extremly high and can use in the same Time VirtualDJ without problems! Only I need 8GB Ram Link to comment Share on other sites More sharing options...
Guest Suikazura Posted May 14, 2014 Share Posted May 14, 2014 My pc laptop should be able to play the game on high, but really can't right now. Most likely not enough memory. It does a pretty good job on medium though. But, same as you, desktop is gaming rig. A little dated now, but until I get working again will have to stay that way. But does a good job. Link to comment Share on other sites More sharing options...
