Haha me neither... it's really ruined at this point. Somehow, at some points the connection words and lets you login.. but then it drops and as soon as you get another loading screen it would start all over again.
Loading screen issues (and more...)
#21
Posted 21 May 2016 - 08:26 PM
#22
Posted 22 May 2016 - 09:01 AM
indeed not possible to login
really shit we have to wait till monday till dev team is back
#23
Posted 22 May 2016 - 09:44 AM
#24
Posted 22 May 2016 - 09:45 AM
It is but you got to keep on trying. For me it usually works after an attempt of 20,something like that. try not to room hope too much though, each loading screen gives you a new chance at getting stuck.
That's so true..
#25
Posted 22 May 2016 - 10:32 AM
hier ook Belgie en ook telenet
problemen bij inloggen , na meerder malen te proberen kom ik dan terecht in mijn appartment , ofwel leeg ofwel ik naakt, geen profile...
iemand oplossing ?
#26
Posted 22 May 2016 - 10:48 AM
iemand oplossing ?
Hey Manty, nope nog steeds geen oplossing voor dit probleem. Sommigen hebben support gecontacteerd en zijn in afwachting...
Hopelijk wordt het probleem snel opgelost.
#27
Posted 22 May 2016 - 12:03 PM
Verwacht geen oplossing voor dev's terug zijn op maandag .
Expect no problems solved before monday when dev's get back to work .
#28
Posted 22 May 2016 - 01:12 PM
Anyhow, the workaround for the profile bug sometimes helps to get a profile to show,
What workaround is that?
#29
Posted 22 May 2016 - 01:19 PM
just so you know , Achilles sended a message to the dev-team .
#30
Posted 22 May 2016 - 02:00 PM
If you spam the "my profile" button on the top right... you'll end up suddenly having a working profile window.
- Nielskeee likes this
#31
Posted 22 May 2016 - 02:03 PM
Awesome! Lisa has responded to me telling that it's best to use the Contact Support form instead of sending to her. I think the support team is where they can actually try and find a solution to this problem.
#32
Posted 22 May 2016 - 02:06 PM
Cool, het werkt! ...mercikes
#33
Posted 22 May 2016 - 02:07 PM
Graag gedaan
#34
Posted 22 May 2016 - 03:15 PM
wat bedoel je met de "my proflie " knop spammen ?
#35
Posted 22 May 2016 - 04:14 PM
De knop die je gebruikt om naar je profiel te gaan... als je daar op drukt dan gaat je profiel open, druk je nogmaals dan sluit die terug. Doe dit x aantal keer en plots laad je profiel terug. Maar helaas is het maar van korte duur dankzij dit
netwerkprobleem.
#36
Posted 22 May 2016 - 04:20 PM
Je kan ook proberen een proxy te gebruiken, ik gebruik "mudfish", welke ik eerder al probeerde voor een mmorpg die ik speelde.. het is wel een betaalde service maar kost helemaal niet veel.. voor 3$ heb je 30gb aan traffic, heb vandaag 6 cent verbruikt van de 3$ op mijn account, maar al mn internet gaat nu door die proxy omdat ik het ip van de gameserver niet ken ^^" zo goed ben ik ook niet met computers xD
Alles gaat nu prima, waardoor je zeker kan zijn dat het een netwerk probleem is..
- Yowan likes this
#37
Posted 22 May 2016 - 05:16 PM
Lijkt een goed plan, op die manier kunnen mensen spelen tot de ontwikkelaars het probleem kunnen oplossen.
#38
Posted 22 May 2016 - 07:38 PM
still nothing here
hope it will be fixed soon
#39
Posted 23 May 2016 - 01:50 PM
#40
Posted 23 May 2016 - 03:21 PM
Had ik al geprobeerd, maar dat leek ook niet te werken.
Also tagged with one or more of these keywords: Slow, unresponsive, loading screen, profiles, server, connection
3DXChat →
Technical Support →
Cannot connect to server!Started by Feuermond , 30 Dec 2018 ![]() |
3DXChat →
Technical Support →
Problems ConnectingStarted by TomaHawk , 10 Dec 2018 ![]() |
Community →
Open Forum →
Forum Challenge while servers are downStarted by Vaughan_Rarius , 08 Nov 2018 ![]() |
3DXChat →
Technical Support →
SERVER DOWNStarted by gizmo , 10 Apr 2018 ![]() |
3DXChat →
Technical Support →
SERVER MAINTENANCEStarted by gizmo , 13 Oct 2017 ![]() |
