kelsapik Posted December 23, 2014 Share Posted December 23, 2014 Hi, Everytime you release a new update patcher works and takkes care of the update installation. But last update didn't work that way for me. I have been trying to resolve the problem with many restarts, uninstallations, downloading the installation file fresh, installing the game again and again with no resolution. Patcher works, does couple downloads and installations and when doing the last update gets stuck. I even left it untouched for two days to see if it was too slow process.. What should I do? Link to comment Share on other sites More sharing options...
Rochi Posted December 23, 2014 Share Posted December 23, 2014 Try this please http://3dxchat.com/forum/index.php?/topic/562-problem-wth-update/ kelsapik 1 Link to comment Share on other sites More sharing options...
kelsapik Posted December 23, 2014 Author Share Posted December 23, 2014 It worked perfectly, thank you very much.It has been a long time since I had to get into registry. Link to comment Share on other sites More sharing options...
kelsapik Posted February 6, 2015 Author Share Posted February 6, 2015 Oh no, Update 264 --> 265 is doing the same thing and I have uninstalled, deleted all 3DXChat from registry, restarted my computer, re-installed again, waited for all updates and got stuck at 265 with the patcher log file stating: -f -d -s "C:/Program Files (x86)/3DXChat/3DXChat_Data/Managed/Assembly-UnityScript.dll_old" "C:/Program Files (x86)/3DXChat/M2HPatcherTMP/WindowsPlayer270/3DXChat_Data/Managed/Assembly-UnityScript.dll" "C:/Program Files (x86)/3DXChat/3DXChat_Data/Managed/Assembly-UnityScript.dll" CALLED (Filename: C:/BuildAgent/work/d3d49558e4d408f4/artifacts/StandalonePlayerGenerated/UnityEngineDebug.cpp Line: 53) UnauthorizedAccessException: Access to the path "C:/Program Files (x86)/3DXChat/3DXChat_Data/Managed/Assembly-UnityScript.dll_old" is denied. at System.IO.File.Delete (System.String path) [0x00000] in <filename unknown>:0 at PatchClientGUI.ApplyPatch (System.String from, System.String to) [0x00000] in <filename unknown>:0 at PatchClientGUI.ProcessUpdateData (System.String folder) [0x00000] in <filename unknown>:0 at PatchClientGUI+<DownloadGame>c__Iterator11.MoveNext () [0x00000] in <filename unknown>:0 (Filename: Line: -1) Any ideas? Link to comment Share on other sites More sharing options...
Gizmo Posted February 6, 2015 Share Posted February 6, 2015 Completely remove the game and its folder.Download the latest installer And reinstall it.http://3dxchat.com/download.php?id=mirror PS: Installer updated to the latest verison 270 kelsapik and Rochi 2 Link to comment Share on other sites More sharing options...
kelsapik Posted February 6, 2015 Author Share Posted February 6, 2015 Thank you Gizmo, it is working fine now. Link to comment Share on other sites More sharing options...
kelsapik Posted February 17, 2015 Author Share Posted February 17, 2015 What is wrong with these patches or my laptop?Patch 273 is doing the same thing again and uninstalling, deleting the registry, restarting, installing 270 does not help. Here is the last entry at output_log.txt -f -d -s "C:/Program Files (x86)/3DXChat/3DXChat_Data/Managed/Assembly-CSharp.dll_old" "C:/Program Files (x86)/3DXChat/M2HPatcherTMP/WindowsPlayer276/3DXChat_Data/Managed/Assembly-CSharp.dll" "C:/Program Files (x86)/3DXChat/3DXChat_Data/Managed/Assembly-CSharp.dll" CALLED (Filename: C:/BuildAgent/work/d3d49558e4d408f4/artifacts/StandalonePlayerGenerated/UnityEngineDebug.cpp Line: 53) UnauthorizedAccessException: Access to the path "C:/Program Files (x86)/3DXChat/3DXChat_Data/Managed/Assembly-CSharp.dll_old" is denied. at System.IO.File.Delete (System.String path) [0x00000] in <filename unknown>:0 at PatchClientGUI.ApplyPatch (System.String from, System.String to) [0x00000] in <filename unknown>:0 at PatchClientGUI.ProcessUpdateData (System.String folder) [0x00000] in <filename unknown>:0 at PatchClientGUI+<DownloadGame>c__Iterator11.MoveNext () [0x00000] in <filename unknown>:0 (Filename: Line: -1) Link to comment Share on other sites More sharing options...
Rochi Posted February 17, 2015 Share Posted February 17, 2015 Umm i have a feeling something like a virus protection is blocking the updates.. Link to comment Share on other sites More sharing options...
Guest Skar Posted February 17, 2015 Share Posted February 17, 2015 Try to run the game as administrator. Right click on the game icon and run as administrator. See if it goes throught this time. Something prevent a file to be deleted. Can be access right or security suite (anti virus). Link to comment Share on other sites More sharing options...
kelsapik Posted February 17, 2015 Author Share Posted February 17, 2015 I have tried running the installer and the game as administrator. Iwill try to stop the mcaffee and run the installer and patches again. Link to comment Share on other sites More sharing options...
kelsapik Posted February 19, 2015 Author Share Posted February 19, 2015 I stopped the antivirus and firewalls before installation and all worked fine. from now on if I see a patcher popping up i will do the same. Link to comment Share on other sites More sharing options...
Eddiefy Posted February 26, 2015 Share Posted February 26, 2015 Would it be possible to add to the exception lists of both the anti-virus and firewall so that we dont have to turn them off every time? If possible what should we add to the list? Link to comment Share on other sites More sharing options...
Guest Skar Posted February 26, 2015 Share Posted February 26, 2015 yes. it possible but it depend what anti-virus you use and if you are using Windows Firewall or your security software firewall. It doable, the how depend really on your computer setup. Link to comment Share on other sites More sharing options...
